Do you have to raise the engine to change the oil pan gasket in 98 explorer w/5.0 engine>
Mar 12, 2007 at 11:04 AM
If the oil pan gasket is rubber, slip it around the outside of the pan without raising the engine. Use the pan set guide pins at the corners near the U-shaped section to hold the gasket while positioning it, and work slowly and carefully.
The owner asked whether the engine must be raised to replace the oil pan gasket on a 1998 Ford Explorer with a 5.0. The expert said a rubber gasket can usually be slipped around the outside of the pan and held with guide pins while it is positioned, so raising the engine is not necessary if the job is done carefully.
