1996 Ford Explorer Grease in Wheel Well
MOPARMAN64
1996 5.0 ltr, all wheeldrive explorer grease around passenger side wheel well splattered fairly heavy.also some on lower control arm.could it be the wheel bearing and is that hard to fix at home . does job require any special tools???? how much is part to buy???
Aug 6, 2007 at 12:59 PM
MERLIN2021
  • 17,250 POSTS
More likly it's the CV-Joit on that side, the dust boot is torn open. The wheel brakes and rotor must come off!
Aug 13, 2007 at 9:41 AM
Suggested Repair
The heavy grease around the passenger wheel well is more likely from a torn CV-joint dust boot than a wheel bearing. Inspect and replace the passenger-side CV joint or boot; the wheel brakes and rotor must be removed for access.
Conversation Summary
The owner of a 1996 Ford Explorer 5.0 AWD reported heavy grease splattered around the passenger wheel well and some on the lower control arm, and asked whether a wheel bearing was the cause, whether it could be fixed at home, what tools were needed, and the part cost. The expert said a torn CV-joint dust boot on that side was more likely and noted that the brakes and rotor must come off.
