1999 Ford Explorer PCM Fuse Blows
TAZZ974
i have a 99 ford explorer that when ever i turn the key on it blows the PCM fuse. i have alreda replaced the PCM its self and it still blows the fuse.
any ideas as to what to try next?
Nov 2, 2007 at 8:13 AM
MERLIN2021
  • 17,250 POSTS
Take the fuse box off the firewall and inspect the back side for a burned wire...
Nov 2, 2007 at 8:29 AM
Suggested Repair
Remove the fuse box from the firewall and inspect the back side for a burned wire.
Conversation Summary
A 1999 Ford Explorer blows the PCM fuse whenever the key is turned on. The PCM has already been replaced, but the fuse still blows. The expert recommends removing the fuse box from the firewall and inspecting the back side for a burned wire.
