1996 Ford Explorer No Start Fuel Pump
REBLIN
I have a 1996 Ford Explorer, 1.9 LT V6 4WD with 206,000 miles. I think that the fuel pump went T-U, because it will turn over just fine, but won't start. When I turn the key, I don't hear the fuel pump kick on. I checked the fuel cut off switch and it doesn't need reset or plugged in. Where is the fuel pump located?
Jul 21, 2006 at 5:52 PM
SERVICE WRITER
  • 9,123 POSTS
In the fuel tank
Jul 25, 2006 at 12:17 PM
GENMAC29
arent there three pumps? how do you know if it is the two inners or the one outer(on a double fuel tank)
Jul 29, 2006 at 6:38 AM
SERVICE WRITER
  • 9,123 POSTS
i don't believe the explorers are like that, at least I haven't run into it.
IF there are double tanks, each tank will have one in it. IF there is an external one in addition, (I think pick ups and vans may apply), It is usually frame mounted. but is meant as a high volume helper pump.
Jul 29, 2006 at 6:47 AM
MIKEYBDMAN
  • 623 POSTS
[quote:759b4ca173="Reblin"]I have a 1996 Ford Explorer, 1.9 LT V6 4WD with 206,000 miles. I think that the fuel pump went T-U, because it will turn over just fine, but won't start. When I turn the key, I don't hear the fuel pump kick on. I checked the fuel cut off switch and it doesn't need reset or plugged in. Where is the fuel pump located?[/quote:759b4ca173]
A few quick things to check before removing the fuel tank are....fuel pump fuse in the power distribution box. Fuel pump relay located in the same power dist box. You can check for power at the plug on the tank on the PK/BK wire. If you have power there as soon as you turn on the ignition switch, and a good ground on the BK wire, then the pump it is.
Jul 29, 2006 at 9:13 AM
Suggested Repair
The fuel pump is inside the fuel tank. Before dropping the tank, check the fuel pump fuse and relay in the power distribution box, then check for ignition-on power at the tank connector (pink/black wire) and a good ground (black wire). If power and ground are present, the pump is likely failed. Explorers are not typically dual-pump setups; if there are two tanks, each has its own in-tank pump.
Conversation Summary
The owner of a 1996 Ford Explorer said it cranks but will not start and the fuel pump cannot be heard. The inertia fuel cutoff switch was already checked. Experts said the pump is in the fuel tank and advised checking the fuse, relay, and power and ground at the tank connector before removal. They also said Explorers are not typically equipped with multiple pumps; dual tanks would each have one in-tank pump, while an external helper pump is more common on some pickups and vans.
