1998 Ford Explorer DEAD!
CMARIE
  • 1998 FORD EXPLORER
1998 Ford Explorer w/135,000 miles would not turn over. Replaced the fuel pump & fuel filter - still would not turn over. Replaced the fuel pump relay - started to turn over but will not start up. Checked all the fuses, none are out. Seems like a simple problem but cannot figure out. Any help would be greatly appreciated.
Tuesday, November 13th, 2007 AT 11:30 AM
MERLIN2021
  • 17,250 POSTS
If it's getting gas, check for spark, pull a plug wire and put a used plug in it, ground it and dissable the fuel system, crank engine, any spark?
Tuesday, November 13th, 2007 AT 5:13 PM
ED51
  • 16 POSTS
Reset the fuel pump shut off located near the passenger side kick panel. Or if you have a car theft alarm installed, it is malfunctioning. The alarm is linked to the PCM. If it is a manual transmission the clutch pedal starter switch is faulty. Bad PCM or ignition fuse.
Sunday, October 28th, 2012 AT 8:32 AM
