Front End
KRISTI
I have a 1998 Ford Explorer Sport with a V6 and 120,000 miles. I started hearing a clunking noise around the front drivers side tire. I had the tires checked, they are almost new, and there was no problem. Today, it started to squeel and clunk, especially when turning. It sounds like something has broken loose. I was worried I wouldnt get home. I live in the country, a single mom, and could really use your advice. I am scared to drive it after I got it home. I have never had any problems with this vehicle other than normal upkeep. It just sounds like metal clunking and squeeling by the tire, mostly when I turn.
Nov 26, 2007 at 11:45 AM
BMRFIXIT
  • 19,053 POSTS
[quote:fb04bc9de2="kristi"]I have a 1998 Ford Explorer Sport with a V6 and 120,000 miles. I started hearing a clunking noise around the front drivers side tire. I had the tires checked, they are almost new, and there was no problem. Today, it started to squeel and clunk, especially when turning. It sounds like something has broken loose. I was worried I wouldnt get home. I live in the country, a single mom, and could really use your advice. I am scared to drive it after I got it home. I have never had any problems with this vehicle other than normal upkeep. It just sounds like metal clunking and squeeling by the tire, mostly when I turn.[/quote:fb04bc9de2]
Check stabilizer links and front end
And if all ok
Check radius arm bushings
It’s the arm that between the front differential and the farm almost under the seat from the out side
Nov 26, 2007 at 11:59 AM
