2003 Ford Explorer Keypad Code
JENWARD29
How do I find out what the keypad code is on my Explorer? When I bought it, it did not have the code or an owner's manual.
Feb 1, 2007 at 10:46 AM
TAURUSWHEEL
  • 718 POSTS
The factory usually puts a sticker with the code in a couple of places depending on your vehicle.. sometimes on top of the keyless module, the GEM module, the pcm unit itself, possibly a couple of other places... if all fails, the dealer, for a price, can pull it out of your pcm with their ngs tester.. I've looked all over my manuals for info specific to getting it out of the pcm and I can't find it..
Feb 2, 2007 at 8:58 AM
Suggested Repair
Look for a factory sticker with the keypad code on the keyless entry module, GEM module, or PCM. If it cannot be found, a dealer can retrieve the code from the PCM with an NGS tester.
Conversation Summary
The owner of a 2003 Ford Explorer wants the factory keypad code, which was not provided at purchase and no owner's manual was included. The expert says the code is often on a sticker on the keyless module, GEM, or PCM, and a dealer can pull it from the PCM with an NGS tester if the sticker cannot be found.
