Exhaust manifold/passenger side
TIMBERWOLF
Have a 1998 Ford Explorer XLT v-8, heard a "pop" then what sounded like a cyclinder compressing air out of a hole, like a spark plug had let go. Not the case. I examined the exhaust manifold and saw a clean bore hole that might have housed a sensor of some sort. Q: Can this be repaired, what goes in there and will it be expensive? :(
Nov 30, 2007 at 5:23 AM
MERLIN2021
  • 17,250 POSTS
Depends if the threads are good, you have a popped 02 sensor, they cost anywere from 60.00 to 150.00 or so, depending were you buy it. Screws into that hole and plugs into the wiring harness...
Nov 30, 2007 at 5:38 AM
