1993 Ford Explorer Acceleration Issues
TEXASJENN
  • 5 POSTS
93 Explorer, 156,000 miles, v6. Don't know if I have bad gas, bad fuel pump or something else. No stalling as of yet. Starts fine, sometimes I have a small rough idle (very rare), but am having acceleration problems. It just feels like it's not getting gas. It shifts fine. It's not all the time only occasionally. It might drive fine on the way to work, but act hokey on the way home. Usually after it warms up a little it drives ok but still doesn't feel like it's pulling right. I've had the fuel filter changed, injectors cleans and new spark plugs/wires. I sometimes get a "check engine" light but not always. I have taken it to one Autozone to see if they can run a scan for me but they are saying my car is too old. Maybe it's just that Autozone...not sure. Any ideas on what it could be?
Oct 14, 2007 at 4:36 PM
  • 75,988 POSTS
I've found on these fords the ign. coil pack can cause all kinds of probs. You may want to get the ignition system scoped. Try removing the coil pack, look at its underside for a black pattern on the filler poured in the coil. this can cause crazy problems.
Might also want to check the fuel pressure.
Oct 14, 2007 at 10:20 PM
Suggested Repair
Have the ignition system scoped and inspect the coil pack underside for a black pattern in the filler. Also check fuel pressure.
Conversation Summary
The owner of a 1993 Ford Explorer with 156,000 miles reports occasional weak acceleration that feels like a fuel problem, rare rough idle, and an intermittent check engine light. The fuel filter, injectors, spark plugs, and wires were already serviced. The expert suggests scoping the ignition system, inspecting the coil pack underside for a black pattern, and checking fuel pressure.
