Ford Explorer Stutters on Acceleration
VANRIK
How can I narrow this down? I have just recently noticed that when I drive my Explorer and especially on the highway, when I go to give it gas the vehicle stutters. The check engine light flickers on and off until I let up on the gas. It has new spark plugs, MAF sensor, both oxygen sensors have been replaced, and as well as the vacuum line. Other than that it runs really well, except when you really need to give it gas, it is really getting frustrating! Please help.
Jul 17, 2007 at 12:03 PM
ECGRANT
i have a similar problem... noticed the stutter at cruise with the check light... any results from your search you could share?.. ecgrant (loucgrant@aol.com)
Aug 14, 2007 at 7:55 AM
MERLIN2021
  • 17,250 POSTS
In your case were the MAF has been changed, Get the code read for the check engine light. Autozone will do it free. Post results here. Maybe have the fuel pressure checked too.
Aug 14, 2007 at 8:20 AM
Suggested Repair
Have the check engine light codes read, then check fuel pressure. Post the code results for further diagnosis.
Conversation Summary
A Ford Explorer stutters under acceleration, especially on the highway, and the check engine light flickers until the throttle is eased. Spark plugs, the MAF sensor, both oxygen sensors, and a vacuum line were already replaced, and it otherwise runs well. The expert advised reading the trouble codes and checking fuel pressure.
