2001 Ford Explorer Stutters when accelerating
98,000 MILES • V8 • AWD • AUTOMATIC
JJSZABO
My car spits and stutters, feeling like it will stall when I lightly push on the accelerator. It doesn't happen when at neighborhood speeds only when I hit about 40 mph and up. But if I push down the accelerator the sputtering goes away. I have no problem idling, going slow, or cruising. I just had the manifold replaced, could that be causing this?
Nov 4, 2010 at 1:18 AM
  • 75,988 POSTS
Hi jjszabo, Welcome to 2carpros and TY for the donation
Clean the MAF sensor with an electronic cleaner CRC and test the throttle position sensor-
Nov 4, 2010 at 1:41 AM
JJSZABO
I guess my issue is that this problem began after getting my manifold replaced. It seems too much of a coincidence, since I never had this problem before I dropped it off to be repaired. Then immediately after I pick it up this happens. Could the repair be causing this or maybe something was bumped, damaged when they were installing the new manifold?
Nov 8, 2010 at 1:05 AM
  • 75,988 POSTS
Check the EGR valve and IMTV, also all wiring connectors within the intake manifold and vacuum hoses
Nov 8, 2010 at 3:39 AM
