2004 Ford Explorer rotors
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
TEE2LOE
how dou remove rotors they seem to be stuck after brakes are removed should i tapon rear
Aug 27, 2009 at 3:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
bang on them some with a rubber headed mallet. the brake heat causes the rotor to stick. if it is the rear rotors, ensure your parking brake pads and linings are loosened so it is not holding on the rotor still.
Aug 27, 2009 at 7:20 PM
