my explorer is a 1993 4.0L 4x4 eddie bauer edition with 310 000 kms on it
thanks for any help in advance
Yes, the automatic hub locks must come off to remove the rotors. Use a repair manual, work one side at a time, and keep parts in removal order. Clean and regrease the bearings, preferably with new seals. Seat the outer bearing by snugging it, backing off, then tightening to about 15 ft-lbs (hand-tight on the socket, no ratchet). Be careful with plastic auto-hub parts and use or rent the special hub-nut socket; a modified old socket may work.
The owner of a 1993 Ford Explorer 4.0L 4x4 Eddie Bauer asked whether the automatic lockers must be removed to take the rotors off for turning and new pads. The expert confirmed they do, recommended a repair manual, and advised working one side at a time, lining parts up in order, cleaning and regreasing the bearings with new seals, and seating the outer bearing to about 15 ft-lbs. They also warned about plastic auto-hub parts and a special hub-nut socket, which can sometimes be rented or made from an old socket.
