2004 Ford Explorer flow problem
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
SSATTAR
when iam going to more then 120 km/h then this front windows was closed and dashboard windos open .please tellme what can ido
Oct 6, 2010 at 6:53 PM
  • 110,248 POSTS
Hi:
I'm not sure I understand what you are asking. Are you saying when you reach that speed, the windows close? Also, what are dash windows?
Oct 7, 2010 at 5:34 AM
SSATTAR
iside the front miror or glassor screen 02 windows one driver side one other side when you want to change the flow towords fronnt screen
Oct 7, 2010 at 9:29 AM
  • 110,248 POSTS
Okay, I think I understand. Are you saying that the air flow switches between the defroster to the windshield and the air vents on the dashboard?
Oct 8, 2010 at 4:43 AM
SSATTAR
yes this is problem
Oct 8, 2010 at 5:13 AM
  • 110,248 POSTS
First, I'm sorry that I didn't understand the first time.
What you are dealing with is a vacuum leak. The vent doors that direct air flow are actuated by engine vacuum. When you reach that speed, the vacuum is lower in the engine. If you have a leak, the air flow direction will change.
Check under the dash for a dry rotted, damaged, or disconnected hose. Also, you may want to check under the hood for the same. If you are lucky, with the engine running, you may hear a hissing sound where the leak is located.
Oct 8, 2010 at 5:29 AM
