HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine
Symptoms
Revs Up
SPONSORED LINKS
2004 Ford Explorer
MONSHAE
MEMBER
2004 FORD EXPLORER
Engine Performance problem
2004 Ford Explorer 6 cyl Four Wheel Drive Automatic
rpm goes from 1000 to 600 car is bucking and then runs fine and does it again
Thursday, March 26th, 2009 AT 9:18 PM
OBXAUTOMEDIC
MECHANIC
Check for vacuum leaks.
Check IAC (Idle Air Control Valve)
SPONSORED LINKS
Thursday, March 26th, 2009 AT 9:45 PM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
Cannot Drive Over Ten Mph
When I Am Driving I Cannot Drive Over Ten Miles Per Hour And My Rpm Are Staying At 1000.
Asked by
Ptak91
1 ANSWER
1 IMAGE
2004
FORD EXPLORER
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
2004 Ford Explorer
Engine Mechanical Problem 2004 Ford Explorer 6 Cyl Four Wheel Drive Automatic My Ford Explorer 2004 Model Acceleration Not Posible...
Asked by
smalekal
2004
FORD EXPLORER
Engine Revving
Sometimes In A Pull The Explorer's Engine Will Rev Up And The Rpms Will Rise Up Almost Like The Transmission Will Not Gear Up Or Down....
Asked by
whitetailhunter
1 IMAGE
2006
FORD EXPLORER
1996 Ford Explorer Revving Up
K, 2 Part Question, 1st, I Just Got This Truck 2 Days Ago, But Today, The Moter Is Revving Up From 600rpm To About 1000rpm, Just Real...
Asked by
inneedofhelpreallybadly
1 ANSWER
1996
FORD EXPLORER
1998 Ford Explorer Engine Revving Problem
I Am Experiencing An Issue Where While Under Normal Driving Conditions The Engine Makes A High Revving Sound While The Tachometer Indicates...
Asked by
jpresson
1998
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak Test and Repair
Online car repair manuals
