white smoke from the exhaust?
68,000 MILES • 6 CYL • 4WD • AUTOMATIC
ALMOTEAM
. recently whenever i start the car i get a huge puff of white smoke coming from the tail pipe. I know its not your typical condensation. It usually clears up after a minute or two. Also my engine light just came on. Any ideas.
May 22, 2010 at 10:44 PM
94 TRANSAM
  • 680 POSTS
You should goto a parts store and have them pull the codes for you so you know what they are if you don't own a code reader. As for the smoke. White smoke is oil burning. This can be caused by worn out cylinders or bad valve seal or worn out valve guides. If you do a compression test that will tell you if the cylinders are worn out. If they are not then it is likely a valve issue.
If you don't have a compression tester they are cheap from Harbor Freight.
Let us know what you find out. And you can let us know what the codes are if you get them.
Rich
Jun 12, 2021 at 5:58 AM
