HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Brakes
Rotor
Replace/Remove
2003 Ford Explorer removing rear brake rotors
BOBOLINC158
MEMBER
2003 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
88,000 MILES
Is there something I am missing? I have removed the calipers and retainers on studs but the rotors willnot come off.
Sunday, March 7th, 2010 AT 6:46 PM
OBXAUTOMEDIC
MECHANIC
Yes, you will need to adjust the E-Brake in. The E-Brake is just like the old Brake Shoes just narrower. And located inside the Rotor.
SPONSORED LINKS
Sunday, March 7th, 2010 AT 7:37 PM
Please
login
or
register
to post a reply.
Related Brake Rotor Replace/Remove Content
Rotor Removal
I Am Doing A Front Brake Job On My 1999 4wd Explorer. After Completely Removing The Calipers, I Am Unable To Remove The Rotors From The...
Asked by
mfreeland
1999
FORD EXPLORER
1994 Ford Explorer Rotor Removal
How Do I Go About Removing The Front Rotors? I Have Done Planty Of Brake Jobs But On This Model I Cannot Remove The Rotor Without A Special...
Asked by
sseese
1 ANSWER
1994
FORD EXPLORER
1992 Ford Explorer Remove Rotors
Is Ther A Trick To Removing The Rotors, They Wont Just Pull Off. Is There A Bolt Or Something That Has To Come Off Or Do I Just Keep...
Asked by
yte
1 ANSWER
1992
FORD EXPLORER
Brake Rotors
I Recently Replaced The Front Rotors On My 1994 Explorer Sport 2wd V6, By The Book. Since Then The Passenger Side Front Locks Up Just...
Asked by
johnjr88
1994
FORD EXPLORER
1994 Ford Explorer Rotors
1994 Ford Explorer How To Remove Rotors
Asked by
lclossy
1994
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Wheel Bearing Replacement
Wheel Stud Replacement Chevrolet Cavalier
CV Axle Bearing Press
Online car repair manuals
