2003 Ford Explorer Park Lights
89,550 MILES • 6 CYL • 4WD • AUTOMATIC
MKRISE77
I have had my Explorer in the shop. they replaced sensors, relay switches & different types of fuses. I even had the turn signal assembly changed to no avail. The problem is that when I either shut the driver door or push the lock button on the keyless entry pad the park lights come on & remain on. I then have to unhook the battery to keep the battery from running down. Is this a simple fix or a big problem? Any help would be greatly appreciated. Thank you for your time in this matter.
Oct 19, 2009 at 3:37 PM
CARLIFE65
  • 200 POSTS
you have a bad delay switch
Oct 25, 2009 at 10:19 AM
MKRISE77
You said that I have a bad delay switch. Are there different types of delay switches or just one kind? Is it simple to fix or would I have to have it taken to a Ford dealership? Where is this certain delay switch located? Anymore details would be greatly appreciated. Thank you so much for your time in this matter.
Oct 25, 2009 at 11:29 AM
CARLIFE65
  • 200 POSTS
it should be driver side on you dash panl,on your light switch
Oct 27, 2009 at 3:51 AM
