HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Exterior Light
Running Light
Not Working
No brake lights or Tail lights
HJKS48
MEMBER
FORD EXPLORER
1998 Ford Explorer
104,000 miles
4.0 V6 4D 2WD
Changed bulbs and checked fuses. I'm at a lost.
Thursday, October 11th, 2007 AT 12:51 AM
NEEDSNO
MEMBER
1 POST
There is a relay switch mounted on the brake pedal. This is most likely the root of your problem
SPONSORED LINKS
Monday, October 22nd, 2007 AT 9:20 AM
Please
login
or
register
to post a reply.
Related Running Light Not Working Content
2002 Ford Explorer Tail Light Won't Work.
My Driver's Side Tail Light Will Not Work. I Repalced The Bulb Twice. I Tried The New Bulb In The Passenger Side And The Bulb Worked, So...
Asked by
Proxmire13
2002
FORD EXPLORER
Rear Tail Lights
Turn Signals, Backup, Flashers, Brake Lights All Work, But No Parking Or Tail Lights.I've Replaced Bulbs, And Light Switch. The Lights...
Asked by
Bob22858
1998
FORD EXPLORER
Left Rear Brake Light And Turn Signal Not Working
Left Rear Brake Light And Turn Signal Not Working. Have Changed Bulb, Socket And Checked Fuse On Dash By Drivers Door.
Asked by
john1eye
2 IMAGES
2001
FORD EXPLORER
Running Lights And Dash Not Working
Replace Or Test? How To Replace Headlight Switch? Running Lights And Dash Not Working. Headlight Switch Install.
Asked by
Jeridiley
1 ANSWER
4 IMAGES
1995
FORD EXPLORER
How To Disable Auto Lamp Feature
I Want To Disable The Auto Lamp In My '98 Explorer. I've Located The Five (5) Wires That Lead To The Auto Lamp Mirror: - White W...
Asked by
Dan Dimond
1 ANSWER
1998
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Headlight Dim or Dull
Have a Dim Headlight? - Try Replacing This!
Online car repair manuals
