When I turn the temperature control, it continues to blow hot air even when dialed all the way to cold. I recently had some work done on it because when you selected the 'floor' setting it stayed on defrost. That seems to be ok but now I can't adjust the temperature. Any thoughts? Thanks!
Feb 18, 2009 at 12:43 PM
