HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Climate Control
Heater
SPONSORED LINKS
1994 Ford Explorer heater
TOMMIE HARRIS
MEMBER
1994 FORD EXPLORER
Engine Cooling problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic 254.25 miles
my heater get hot sometime and then go cold and I have to put antfreeze in it and tempture gage show it hot
Thursday, January 28th, 2010 AT 10:43 AM
KHLOW2008
MECHANIC
Hi tommie harris,
Thank you for the donation.
When coolant is insufficient in the cooling system, the heater would work erratically and the temperature would be hot.
You would need to check what is causing the loss of coolant and rectify it first.
Remember to bleed the system
SPONSORED LINKS
Thursday, January 28th, 2010 AT 11:46 AM
Please
login
or
register
to post a reply.
Related Heater Content
2003 Ford Explorer Need Help Heater's On High But...
I Can Turn My Heater On But Nothing Is Coming Out When I Turn It On The Floor Setting But When I Turn It On Other Settings I Can Feel Air....
Asked by
pocolachristian
2003
FORD EXPLORER
GUIDE
Heater
Once the engine has been started and has run long enough to warm up the hot coolant is transferred into the heater core which is located inside the passenger compartment via...
Vehicle Will Not Go In Gear When Heater Is On
If Heater Is Off, Car Goes In Gear Fine. When Heater Is On, It Won't Come Out Of Park? What On Earth Could Cause This? I'm Not Sure If...
Asked by
alphaomega
2004
FORD EXPLORER
1997 Ford Explorer Heater Quit
Heater Problem 1997 Ford Explorer 6 Cyl Four Wheel Drive Automatic I Am Confused As My Heater And A/c Were Working Then All Of A...
Asked by
taz1962
1997
FORD EXPLORER
1996 Ford Explorer Heater Stuck On Heat
My Heater Seams To Be Stuck On Hot. I Turn The Knob To Cool And I Can Hear A Cable Move But Nothing Happens. I Tried To Get To The Sound...
Asked by
mulliganjack
1996
FORD EXPLORER
1998 Ford Explorer Heater
I Hopeb You Guys Can Help Me!
Asked by
cliff2010
1998
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Heater Not Working
Heater Not Working
Blend Door Actuator Replacement
Online car repair manuals
