1997 Ford Explorer heater quit
TAZ1962
Heater problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic
I am confused as my heater and a/c were working then all of a sudden they quit. Not sure where to start looking?
Oct 12, 2008 at 12:05 PM
BMRFIXIT
  • 19,053 POSTS
Start by checking the fuses
check the blower motor and its connection
Oct 12, 2008 at 12:43 PM
TAZ1962
I have checked all the fuses and they are all OK. and the connection to the blower moter seems snug...Now what? Thanks in advance!
Oct 12, 2008 at 1:25 PM
KERENSELF
  • 54 POSTS
I'm assuming that your blower motor is not coming on.....If you have a test light or volt meter I would check for power at the plug in for the motor. If power is present, then you have a bad motor. If there is no power at the plug, you would need to go backwards through the wiring to determine if it is a bad resistor (which alters voltage to the motor to change the speed), a bad relay, wiring, or switch.
Oct 12, 2008 at 3:15 PM
