1997 Ford Explorer Heater
14,400 MILES • 6 CYL • 2WD • AUTOMATIC
JAMES LEE
My '97 Ford Explorer heater blows hot air all the time. How do I get to where the blend door is and/or the vacuum connection to check them?
Jan 11, 2008 at 12:54 AM
FISHERMAN
  • 937 POSTS
[quote:784300a5c2="James Lee"]Heater problem
1997 Ford Explorer 6 cyl Two Wheel Drive Automatic 144,00 miles
My '97 Ford Explorer heater blows hot air all the time. How do I get to where the blend door is and/or the vacuum connection to check them?[/quote:784300a5c2]
Hello !!
start checking the heater core valve..
could be "stuck open" it is located on the firewall behind your engine in pass. side
(you will see a couple of hoses going there)
good Luck!
Jan 11, 2008 at 1:12 AM
