4 wheel drive does not work
  • 109,885 POSTS
It sounds like the 4wd actuator that is attached to the transfer case that is bad. Check to make sure it is getting power. If it is, chances are it is bad.
Let me know what you find.
Monday, December 21st, 2020 AT 9:54 AM (Merged)
MURPHY10292004
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 42,000 MILES
I have owned the SUV since new and have rarely engaged four wheel drive, high or low. During a recent snow I pushed the button to engage four wheel drive high and got nothing. Fuses are OK. I was told there is a four wheel drive module. How can it be tested to see if it needs replacement? I know it is located behind the glove box so it is easy to reach and replace. I just do not want to buy a module only to find it was something else.
MCGRUFF_CU
I have an 02 Expl V8 with the exact same problem. It has been that way for a year now. I finally got into some snow on a mountain road where I needed it and. Nothing.
Disconnecting one of the battery cables for a moment will reset the module. After that it will work for anywhere from a couple of hours, to all day. Then it's back to nothing.
I paid $100 to get it diagnosed at the local Ford Dealership. It is a bad module (behind the glovebox). Quoted $600 to fix.
I'm still keeping an eye out for a used one from a junk yard (haven't looked real hard).
GLEN B
  • 6 CYL
  • 4WD
  • 130,000 MILES
4x4 not engaging. Lights on dash not lighting up. 3 push buttons on dash to engage 4x4. All fuses are good
  • 109,885 POSTS
Chances are there is a problem with the actuator on the transfer case. I need you to check to see if there is power to it when someone tries to engage the 4wd. If there is power, remove the actuator and have it checked. It is somewhat common on these vehicles for them to go bad.
NILICH00
I am having problems with my 4 wheel drive on my 2002 ford explorer eddie bauer. The indicator lights on the dash do not turn on. When I start the car the only 4 wheel drive light that turns on is the 4x4 low. I have tried using the push button 4 wheel drive and it is not engaging at all. I'm not sure where to begin here. Could you possibly tell me what might be wrong?
Again, when I attempt to use 4 wheel drive, it is not working at all. No idicator lights, noise and response what-so-ever. Any information would be greatly appreciated.
Thanks
Monday, December 21st, 2020 AT 9:55 AM (Merged)
NOS
  • 320 POSTS
You may need friends help on this. One needs to be in the truck and one under driver side of truck at the back of the transfercase. There is a little motor which inguages the transfercase. You won't need to start truck turn key to run while friend turns the selector switch to all spots and lightly tap on the little motor NOT Hard. Ford says you should activate it at least twice a month weather you use it or not just to keep it freed up. Let me know if this works and we go from there. 8) NOS
DCRDANNO
  • 6 CYL
  • 4WD
  • 52,500 MILES
This problem was gradual over several months. At first when starting the car the four wheel drive light would flash indicating to "service the four wheel drive" without noticable problems. Then, after starting, the indicator light would flash and when putting it into reverse and turning as if out of a parking space, it would feel as if the four wheel was engaged and would abruptly "clunck" out as if disengaged. This happened intermittantly for a couple of months. I tried letting the vehicle warm up for say 15 minutes in the morning and the light indicator would not flash anymore, I would not feel that clunck, and the four wheel drive would engage no problem and no indicator light. Almost like there was some connection with temperature, cold it would happen them warm it wouldnt. After a couple more months the light stopped lighting and no four wheel drive working at this time. Also no feeling of engaging or disengaging. Good luck with this one and thanks in advance!
MERLIN2021
  • 17,250 POSTS
On the transfer case find the actuator motor, have someone press the buttons while you tap it with a hammer. If it works, the brushes, or contacts inside it are possibly corroded a bit, may work to free them up, if not check for power at this motor, if power is present, replace motor.
GEARMOTOR ENCODER ASSEMBLY Removal and Installation 1. Press the 4X4 HIGH button on the mode select switch (MSS). Fig. 53: Locating 4X4 High Button On The Mode Select Switch Courtesy of FORD MOTOR CO. 2. Raise and support the vehicle. 3. Disconnect the gearmotor encoder assembly harness connector. Fig. 54: Disconnecting Gearmotor Encoder Assembly Harness Connector Courtesy of FORD MOTOR CO. 4. Remove the bracket bolt and gearmotor encoder assembly mounting bolts and remove the gearmotor encoder assembly. Fig. 55: Removing Bracket Bolt And Gearmotor Encoder Assembly Mounting Bolts Courtesy of FORD MOTOR CO. 5. Remove the grease from the motor adapter and check for any nicks or burrs. If any damage is found, repair or install a new gearmotor encoder assembly as necessary. For additional information, refer to TRANSFER CASE - AUTOMATIC SHIFT . 6. To install, reverse the removal procedure. Ã Â Â Apply a coat of Multi-Purpose Grease to the gearmotor encoder assembly.
https://www.2carpros.com/forum/automotive_pictures/62217_motor_1.jpg
  • 6 CYL
  • 4WD
  • 86,400 MILES
Checked all fuses, relays and diodes. Checked for power to push buttons, have ohms out have power to wheel speed sensors, and transfercase moter. My diognostic program says no communication with electronic 4x4 module. I have power to it but no way to check information out. I hate to buy one on a guess. Its $314.00 dealer item only. Help
  • 109,885 POSTS
Remove the actuator, plug it in, and see if it is functioning. Pay attention to the power supply. Does it drop when the motor is engaged. If so, check the swith and relay again. They could work fine when not under a load.
MARCUM03
  • FORD EXPLORER
I have a 2002 4x4 Ford Explorer. The 4x4 does not work. None of the LED's (Auto, High, or Low) on the switch light up. With a volt meter, I checked to see if voltage was coming to the switch. It does & as the dimmer for the main lights are dimmed, the voltage is reduced accordingly. I accessed the switch was bad & replaced it. This was not the problem. No fuses are blown. A mechanic connected it to his scanner & got a code 735. This relates to 5th grear not being correct ratio. It has no 5th gear, but has an automatic transmission. He checked the grease in the crank case but levels were fine. It has only been
used once or twice but the last known time it worked, all was well. Just one day when I tried to engage it, all seems totally dead. Please advise what to look for next.
Terry
Monday, December 21st, 2020 AT 10:45 AM (Merged)
MIKEYBDMAN
  • 623 POSTS
I would check for power at the 4WD control module. You must select the 4WD on to check for power. The pins should be pin 8 and pin 17. These are the BK/WH and WH wires. This should be your power and ground pins. If do not have power, then find where you are loosing the ground or power.
If you have power to the conrol module, then there are a series of test that will need to be run to isolate the problem.
MARCUM03
When my mechanic connected his scanner to the SUV, it detected each position the switch was in (Manual, High, Low), only no lights come on or no reaction from the crank case.
Do you think the shift motor or sensor could be the problem?
