If your drivers side window is the only one that works and all the other windows (passengers, passengers rear and drivers side rear) do not, you could have possibly activated the "All Windows Lock" toggle switch to the "ON" position. The switch is located right on the power window console on the drivers door. It is like a rocker switch. One position for "On" the other position for "Off". Just flip the toggle/rocker switch in the other direction and see if the windows work.
Usually the white lettering "Windows Lock" gets worn off.
It is actually a safety device that turns the power to all the windows except the drivers off so children can not open or close any of the windows. You control all opening and closing of windows from "your" control console only.
I hope this helped and solved the problem.
If it has not get back to me and we will try something else and eventually solve the mystery.
Rick
Nov 30, 2009 at 11:24 PM
