2002 Ford Explorer Power windows don't work
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
JNELLERS
All 4 windows quit working. My manual is useless as far as labeling fuses. Everything but power windows are listed. I have fuses under the hood on each side, under the dash on the driver's side and one in the back on the passenger side. The manual only describes the fuses in the large fuse box under the hood on the driver's side. can you tell me which fuse it is? I have alreadey had the smaller fuses tested, but they said they couldn't test the larger black fuses. Thanks for the help!
Apr 16, 2008 at 1:01 PM
TTRAN
  • 45 POSTS
Do you have 12v at the plug of each window motor with the ignition on?
Apr 17, 2008 at 10:27 AM
GRANTMCFLEEG
power switch
Jan 11, 2011 at 5:17 PM
