I understand how to remove the window reg and motor, how do I undo the window from the regulator track.
Thursday, May 6th, 2010 AT 9:11 AM
MIKE H R
MECHANIC
If I understand this right you want to remove the regulator from the assembly? In the c-channel bracket there is a piece of metal at a 90 degree angle at the end. Bend it down on the track enough to remove the slide arm. When reassembling it you will have to bend it back up so it is at a 90 degree angle.
SPONSORED LINKS
Thursday, May 6th, 2010 AT 12:31 PM
LFTHNDSHOT
MEMBER
I need to remove the glass from the track or reg
Thursday, May 6th, 2010 AT 12:49 PM
MIKE H R
MECHANIC
I have looked on Mitchell 1 and on e bay to find a window so I can see how it goes in. In the books it does not tell how to replace the glass or show a picture. Not sure if it was a ford but I have seen some windows that had bushings and screws holding the rail to the window. If there is nothing holding the window in the frame then I would guess it is pressed in. Is the old window broken? If so look at it to see if the weather striking holds it in. They have special tools to put them in. I will keep looking to see if I can find anything out.
