2002 Ford Explorer
PHUNKSOULBRUVA
  • 2002 FORD EXPLORER
2002 Ford Explorer
how do I fix rear power window that has gotten off its track?
Monday, September 7th, 2009 AT 7:10 PM
  • 109,896 POSTS
You need to remove the door panel and check to see if the track is broken, detached, or if the adheasive that holds the glass in has dried out.
Thursday, September 10th, 2009 AT 8:58 AM
PHUNKSOULBRUVA
Thanks for the help, any hints on how to get the panel off without breaking all the attachment pieces? I only found one screw at the bottom of the panel, and when I removed that screw and tried to pry the panel off, a plastic attachment piece broke off and fell out the bottom. So I stopped and logged on here. Thanks for any help!
Thursday, September 10th, 2009 AT 10:08 PM
  • 109,896 POSTS
There should be a few more screws. Did you remove the arm rest? Also, many times the plastic clips will break.
Thursday, September 10th, 2009 AT 10:15 PM
PHUNKSOULBRUVA
Thanks, I'll give it another try.
Thursday, September 10th, 2009 AT 11:06 PM
  • 109,896 POSTS
Let me know how it goes for you.
Thursday, September 10th, 2009 AT 11:07 PM
