Electrical problem
2002 Ford Explorer Two Wheel Drive Automatic
My left rear taillight assembly turn signal is not working nor is the stoplight. I have already replaced the bulb with a known good bulb. It does the typical thing when you try to use the turn signal, fast clicking noise and fast flashing of the left front indicator. I suspect that it may be a relay, but I want to be sure.
Thank you,
William Cochran
Thank you,
William Cochran
Jul 1, 2010 at 2:52 AM
