Possible Starter Solenoid Replacement
CARADIODOC
  • 33,942 POSTS
Still depends on the symptom. If you have 12 volts on the red wire and you have the large fender-mounted relay that is not clicking, you have a defective relay, it isn't bolted to a good ground, or it's the wrong part number. Ford used three different designs that all looked the same but where not interchangeable.
Monday, December 28th, 2020 AT 11:26 AM (Merged)
