2002 Ford Explorer od light
2002 FORD EXPLORER
79,000 MILES • 6 CYL • 4WD • AUTOMATIC
MUSKIEJK
Good morning all. I have 2002 explorer xllt. when driving after around 5 min the od light comes on when i hit 55mph of faster . I am hearing a loud hum in the rear. Ive had teh bearings replaced@ 58000 mi. Had it to mechnic and light wouldnt come on. Apparently he didnt drive it long or fast enough. he said it maight be tranny solenoid switch. Would that solve my problem? Any ideas would be greatly appreciated. Thanks so much
Jan 27, 2008 at 12:07 AM
FLEXY5
  • 512 POSTS
First of all, if it's a trans issue, wheather the light is on or not, the code is stored in memory for 50 drive cycles if the code does not occur again. It sounds like he was just lazy. But, there are probably two problems. the first being the howling noise. The rear differential bearings, ring and pinion need to be inspected. A lot of the late model explorers had concerns with both the rear differential as well as the wheel bearings. This is probably not related to the O/D light unless it has th do with excessive metal on the speed sensor in the rear differential. Have the code checked and post back. We'll talk about the trans concern after we have more info.
Dave
Jan 27, 2008 at 1:59 PM
