1996 Ford Explorer Shift Solenoid C Performance or Stuck Of
LARRYCTURNER
  • 1996 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 165,000 MILES
Hi, I seen a post on this site about this problem with a great little diagram of where all the parts are. I'm curious where shift solenoid C is on this Diagram. I need to replace it so my check engine light stays off and I can pass inspection. Also, will I need a gasket or rebuild kit since I'm going to have to drop the pan? And where do you find these parts? Thanks in advance for any help you can give me. - Larry
Thursday, August 5th, 2010 AT 11:08 PM
  • 109,885 POSTS
I can't go by letters. Here is what I can tell you and I hope it helps. SS1 will have a gray wire foing to it, SS2 will have a brown wire go to it, and SS3 will have a yellow. All three will also have a white wire. The white is the power wire, and the others are the signal wires.
Let me know if this helps.
Saturday, August 7th, 2010 AT 11:45 PM
