2002 Ford Explorer Not blowing correctly
107,000 MILES • 6 CYL • FWD • AUTOMATIC
DBURNETTE81
Air cond. is blowing through the defroster and floor but not thru the front vents. Seems to be blowing fine through the rear vents.
Oct 4, 2008 at 1:14 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a vacuum source problem. There should be a small plastic vacuum line that goes through the firewall to the engine. Be sure it is hooked up to the engine. If not there is no vacuum to run the heater controls, this is why it only works on defrost, that is the default when there is no vacuum present at the control head
Oct 4, 2008 at 1:27 AM
