2002 Ford Explorer AC only blows out defrost vents
2002 FORD EXPLORER
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
SUPERDAVE47
MEMBER
1 POST
My ac only blows out defrost vents. I was told to check vacuum resavoir. I can not locate this on my truck. Please help.
Sep 3, 2010 at 3:37 AM
✓Experienced Mechanic
You are dealing with a vacuum leak. Check the hoses under the dash for damage or leaks. If you are lucky, you may hear a hissing from the leak with the engine running.
Let me know what you find.
Sep 3, 2010 at 4:13 PM
