2002 Ford Explorer Engine Seized
DELLARICE
Will Sludge found in the oil pan and the oil pickup screen cause and engine to seize????????
As per garage, timiing chain guides broke and that's what cause engine to seize...PLEASE..advise...HELP!!!!
Jun 5, 2007 at 12:57 AM
BLACKOP555
  • 10,386 POSTS
if the sludge blocked oil from reaching the cylinders then yes. but other than that if that timing chain jumped time it may have ruined your valves and its time to get a new engine
Jun 5, 2007 at 7:07 AM
Suggested Repair
Confirm whether sludge blocked oil flow to the cylinders. If the timing chain jumped time and damaged the valves, plan on engine replacement.
Conversation Summary
The owner of a 2002 Ford Explorer asked whether sludge in the oil pan and pickup screen caused the engine to seize. The shop said broken timing chain guides caused the seizure. The expert said sludge can seize an engine if it blocks oil to the cylinders, but a jumped timing chain may have ruined the valves, requiring a new engine.
