2002 Ford Explorer heat
SADIKA99
  • 2002 FORD EXPLORER
Heater problem
2002 Ford Explorer
The heat in my SUV is blowing cool air.
Tuesday, November 2nd, 2010 AT 1:03 PM
WRENCHTECH
  • 20,761 POSTS
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are.
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Tuesday, November 2nd, 2010 AT 1:37 PM
