2002 Ford Explorer fuel pump
MIKEYE7
  • 2002 FORD EXPLORER
Engine Mechanical problem
2002 Ford Explorer 6 cyl Front Wheel Drive Automatic
what does the fuel pump sounds like. Not sure if its running when trying start the engine. Change the relay once worked fine. Now 2 days later car will not start.
Thursday, February 4th, 2010 AT 4:33 PM
  • 109,885 POSTS
Usually you can hear a soft humming sound from the fuel tank. If it isn't running and you replaced the relay, you need to check if the pump is getting power. IF it is and not running, replace it.
Let me know what you find.
Friday, February 5th, 2010 AT 8:22 AM
