2002 Ford Explorer p a t s system
41,000 MILES • 6 CYL • 4WD • AUTOMATIC
DR BACON
about once a month, vehicle wont start, no power to fuel pump relay. after sitting, starts and runs great.no codes in engine or body. ever hear of this?
May 21, 2009 at 6:05 AM
BMRFIXIT
  • 19,053 POSTS
When it does that did you notice a security light on and flashing
make sure you separate ignition key from others at you key ring
if not check fuel relay and pump
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 22, 2009 at 10:27 PM
