HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Body
Window
SPONSORED LINKS
2002 Ford Explorer driver side window
COMPUTERGAL
MEMBER
2002 FORD EXPLORER
V8
2WD
AUTOMATIC
72,000 MILES
Driver side window barely goes back up and then smells hot
Wednesday, April 7th, 2010 AT 4:12 PM
MECHANIC
Have you checked how many amps the motor is drawing? If you help the window, will it go faster?
SPONSORED LINKS
Wednesday, April 7th, 2010 AT 5:18 PM
COMPUTERGAL
MEMBER
No I didn't try to help it, but I hit the outside of the door near the handle and it slowly went up.
Wednesday, April 7th, 2010 AT 5:35 PM
MECHANIC
I would say the motor itself it bad.
Wednesday, April 7th, 2010 AT 8:56 PM
COMPUTERGAL
MEMBER
Thanks for the assessment. I'll be an aware consumer.
Wednesday, April 7th, 2010 AT 11:46 PM
MECHANIC
Thanks for using 2carpros. Com. Let us know if you have questions in the future.
SPONSORED LINKS
Thursday, April 8th, 2010 AT 10:33 PM
Please
login
or
register
to post a reply.
Related Window Content
2002 Ford Explorer Power Windows
Hi My Name Is Sammy From First Class And I Seem To Be Having A Problem With My Power Windows And Door Lock. I Checked All The Fueses And...
Asked by
firstclass4
2002
FORD EXPLORER
2002 Ford Explorer Window Doesn`t Go Up .
The Window By The Drivers Side Doesn`t Go Up But The Rest Of The Windows Still Working..I Dont Know What Was Wrong. Please Give Me Some...
Asked by
concern39
1 ANSWER
2002
FORD EXPLORER
My Driver's Side Window Was Hesitating For A Few Days And Now It Will Not Roll Up. Also The Back Windows Will Not Roll Down. I Drive A 2002...
Asked by
Joyce Carter
1 ANSWER
2002
FORD EXPLORER
1996 Ford Explorer Power Windows
After I Start The Engine The 4w And 4w Low Indicator Lamps Flash 4 Times And Then Go Out. After That None Of The Power Windows Work To...
Asked by
thewrens1
1996
FORD EXPLORER
Driver's Door Window
The Window On The Drivers Door Vibrates And Will Only Go 1/4 Of The Way Down. Is This A Diy Repair? If So How Do I Get The Panel Off?
Asked by
joe bear
1 ANSWER
1 IMAGE
1995
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Window Switch Replacement and Test
Door Panel Removal
Door Lock Replacement
Online car repair manuals
