2002 Ford Explorer Codes
ROBERT HEISTERBERG II
  • 2002 FORD EXPLORER
  • 6 CYL
  • AWD
  • 104,000 MILES
Code 1400 keeps re-appearing, also is there away to silence the rear end whine and intermiitant grapping of the rear end clutches. Have heard replacing the rear end oil; with a heavier grade and also putting necessary additives could healp. They want $1800 for new ring and pinion set up.
Thanks
Robert
Thursday, February 19th, 2009 AT 7:56 AM
JGAROFALO
  • 489 POSTS
One less expensive alternative would be to get another rear from a salvage yard. Just make sure to get the same gear ratio as the one in the car now.
Rear end noises are generally expensive to repair. The gears are expensive, and setting them up is tedious and time consuming, and requires quite a few special tools. Once a ring and pinion become noisy and start to whine, they tend to stay noisy, even after resetting them up. Heavier oil may lessen the noise, but not by much.
Sunday, February 22nd, 2009 AT 8:55 AM
