Electrical problem
2002 Ford Explorer 6 cyl Four Wheel Drive Automatic
HOW TO REPLACE ABATTERY
Sunday, February 15th, 2009 AT 8:48 AM
MECHANIC
Hi:
First remove the neg cable from the battery then the positive. Make sure not to touch both battery terminals at the same time with anything that will conduct electricity. It will short. Next remove the battery hold down, finally the battery. Reverse the order to replace it.
Let me know if this helps.
SPONSORED LINKS
Sunday, February 15th, 2009 AT 2:12 PM
ZIONDAR
MEMBER
I was told by a mechanic that before disconnecting the
cables of the battery, the cables must be connected to
another battery to prevent memory loss.
Sunday, February 15th, 2009 AT 5:38 PM
MECHANIC
Hi:
Yes there will be memory loss but you can reset things.
