2002 Ford Explorer
ECOCRUISER
  • 2002 FORD EXPLORER
Noises problem
2002 Ford Explorer 6 cyl Two Wheel Drive Automatic
My car has 80k miles. I hear a noise from the rear end that changes with the rpms. It sound like, if I were driving nest to a truck with large tires, that trucks tires rolling down the road. The noise does not change when I am turning corners. One shop says "new bearings" for $700. The other shop say "rebuild rear end" for $3,000. Any guidance would be greatly appeciated.
Saturday, July 12th, 2008 AT 7:39 AM
2CARPRO JACK
  • 11,533 POSTS
3 grand is a little much for a rebuild. I would go with the first shop, they sound as if they know a little more about diffs just due to the fact that they called it a bearing noise and will most likely reuse the gears which are probably still ok.
Saturday, July 12th, 2008 AT 8:32 AM
