2002 Ford Explorer
ULISESS GONZALEZ
  • 2002 FORD EXPLORER
  • 6 CYL
  • 98,000 MILES
How do I change the transmission oil and filter if thers no drain hole or screw
Tuesday, February 23rd, 2010 AT 4:00 PM
  • 109,755 POSTS
To service the trans, you need to remove the trans pan. Slowly open one side and loosten the others so the ATF comes out in one area and not all over you. The filter is under the pan.
Wednesday, February 24th, 2010 AT 6:36 AM
