2000 Ford Explorer
DELVALLE
  • 2000 FORD EXPLORER
Transmission problem
2000 Ford Explorer 6 cyl Two Wheel Drive Automatic
Hi, First time Need some inf. On a OBD11 1747 code. Car Stalls. Thanks, delvalle
Saturday, February 13th, 2010 AT 7:41 PM
  • 109,896 POSTS
P1747 Pressure Control Solenoid "A" Short Circuit
This code is a trany solenoid failure code that pertains to the epc circuit. When this circuit fails, the vehicle will go to a limp mode or harsh shifting including hesitation and stalling. To check verify when the code appears after the code is reset. Use a DVOM and check the voltages going to the epc (electronic pressure control) soleniod. To locate use a wiring diagram so you can locate the epc wires. Once tested, you can verify if the solenoid is working or getting proper voltage signal from the engine computer.
Sunday, February 14th, 2010 AT 2:27 PM
