Where is the Transmission Torque Convertor located on my vehical? I need to see
Jan 5, 2008 at 2:25 AM
ZUE
MEMBER
Your question is not clear to me. The torque converter is located directly between the engine block and the transmission in the area called the bell housing. It allows engine power to be connected to the transmission using fluid preasure which as it increases allows torque from the engine to be delivered to the tranny.
Jan 5, 2008 at 3:21 AM
FLEXY5
✓Experienced Mechanic
I'm not sure exactly what you are looking for though, they cannot be inspected. The torque converters are a sealed unit and are not servicable. If they are bad, they get replaced.
