1999 Ford Explorer so many problem
134,000 MILES • 6 CYL • 4WD • AUTOMATIC
JSFOERTSCH
i have had this vehicle for under a year and have put just about new everything in it. recently the truck would hesitate when i accelerate. oil was just changed, and new fuel pump put in. when i would come to a stop the car idled low, sometimes dying on me. also when it idles low the front end seems to shake. i thought the hesitation might be the fuel filter. so had that changed. still seems to hesitate but not as much. but it still seems to accelerate slow, and shakes when i come to a stop. spark plugs are new within the last 6 months. any help? this car is junk
Nov 16, 2008 at 2:22 PM
BMRFIXIT
  • 19,053 POSTS
Check for vacuum leaks
check intake manifold gasket
do u have check engine light on and if so scan for codes
if all good suspect and check MAF sensor
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 16, 2008 at 10:03 PM
