Any 4X$ will cost more to replace ball joints, as for saftey, I cannot determine that from here! It depends on how much play is in the worn part. Either jack it up and shake the wheels top to bottom and side to side. If it's real worn, you will feel it. Can even be worn shocks, allowing the tires to bounce as you drive.
Monday, May 26th, 2008 AT 1:30 PM
