Overheating
CSWANEY
I took the thermostat completely out, like I said before, the water is running through til it gets to the oil pump, but I dont think its going past it to go to radiator. Could it be the oil pump thats bad?
Friday, August 16th, 2019 AT 2:10 PM (Merged)
Check the water pump its not the oil pump that pumps coolant thruout the engine
CASHRULES80
  • 1993 FORD EXPLORER
Engine Cooling problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic
Put new radiator new thermostat still running hot on me and heat goes out.
  • 109,896 POSTS
Hi:
Did you flush the engine block? Based on the heat loss, is sounds like there is still a blockage. Also, is the vehicle running good other than the overheating? Have you checked to make sure the catylatic converter isn't blocked?
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be hot! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
MSTCMCD
  • FORD EXPLORER
My 1999 Ford Explorer is over heating. Put I am not losing water the car is running hot. I looked and saw that the fan was spinning. Could it be the water pump or thermostat?
CHEVY22
  • 1,375 POSTS
Pull yhe rad cap let the vehicle run until it hits operating temp and fell the upper and lower hoses for heat and also the heater hoses, check for flow in the rasdiator, no flow = bad thermostat or water pump, and def check the hose behind the themostat, you are feeling for hot or cold hoses
thanks, jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
ZW4NZIG
  • 1992 FORD EXPLORER
  • 6 CYL
  • 4WD
  • MANUAL
  • 177,800 MILES
After starting the car cold, it will do a normal heat up routine, but it will go ALL the way to red line, then back off. It seems to back off quicker (Come down to normal operating temperatures) if I am going slower. Higher speeds mean that it stays hotter longer. Also it seems like it's running warmer than it should. It operates a inch or so below maximum temperature. When I shut it off hot, it gurgles a lot and pushes excess coolant into the resevoir. Which I think is normal.
What could be causing this issue?
And as a side note, how much can I expect to pay to replace the clutch in it?
Get the overheating fix 1st try replacing the thermostat and go from there-if it continues get it block and pressure tested.
DORATHEEXPLORER
  • 46 POSTS
  • 1991 FORD EXPLORER
1991 Ford Explorer 6 cyl Two Wheel Drive Manual
Replaced head gasket, water pump, fan clutch, thermostat and radiator cap. Have flushed out system. No leaks or holes in radiator. No busted hoses. No oil in water, no water in oil. Any suggestions?
All those new things on except radiator if its not clogged-up could be airlock try bleeding it if it continues to overheat get it block and pressure tested.
RICKUS
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic
i have replaced the thermostat but after I drive for 15 or more miles it overheats and pushes watter into the overflow compartment, I think the watter pump works and there is watter dripping out of the tailpipe is that a head gasket problem
BLUELIGHTNIN6
  • 16,542 POSTS
Check the engine oil, if it looks milky then you have head gasket issues. Also make sure radiator fan is coming on.
ABUTTRAM
  • 1997 FORD EXPLORER
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic
My husband is trying to change the thermastate on our 1997 ford explorer He has a repair book but it dose not show the right spot where the thermastate si could you help us find It thank you
Friday, August 16th, 2019 AT 2:11 PM (Merged)
DAVE H
  • 13,384 POSTS
THERMOSTAT (EXCEPT 2001 SPORT & SPORT TRAC)
Removal & Installation
NOTE:Make sure the air cleaner outlet tube screw clamps do not interfere with the throttle body cam.
Partially drain the cooling system. Remove the bolts and the accelerator control splash shield. Remove the air cleaner outlet tube. Remove the upper radiator pipe retaining bolt. See Fig. 64 .
Disconnect the hose clamp from the pipe-to-thermostat hose at the pipe end. Remove and position hose aside. Remove the thermostat housing bolts, housing and thermostat. See Fig. 65 . Inspect the "O" ring seal. Install a new "O" ring seal if necessary.
To install, reverse the removal procedure. Tighten bolts to specification. See TORQUE SPECIFICATIONS .
Fig. 64: Removing Upper Radiator Pipe Retaining Bolt
Courtesy of FORD MOTOR CO.
Fig. 65: Identifying Thermostat Housing Bolts
https://www.2carpros.com/forum/automotive_pictures/266999_thermo_3.jpg
ANNE WILLIAMS
1993 Ford Explorer Manual
I believe I have a blown head gasket. Is this something I can fix myself, or is it a more involved repair? How much would a repair shop charge?
BMRFIXIT
  • 19,053 POSTS
Minimum $600 and up
INTAKE MANIFOLDS
Removal (Upper) .Remove negative battery cable.
Remove air cleaner intake duct from throttle body.
Remove snow/ice shield to expose throttle linkage.
Remove throttle cable and bracket from throttle body.
Disconnect all vacuum hoses.
Disconnect all electrical connectors.
Relieve fuel pressure. Using Fuel Line Coupling Key (T90P-9550-A), disconnect fuel supply and return lines at fuel supply manifold..
Remove ignition coil.
Remove upper intake manifold bolts.
Remove upper intake manifold and throttle body as an assembly.
Removal (Lower)
With upper intake manifold removed, remove valve covers.
Remove manifold attaching bolts.
Remove lower intake manifold assembly and gasket.
Remove exhaust manifold.
Remove spark plugs.
Remove accessory drive belt. If removing left cylinder head, remove A/C compressor (if equipped). Remove power steering pump and bracket, and position aside.
If removing right cylinder head, remove alternator and bracket. On all cylinder heads, remove rocker arm shaft bolts evenly by loosening bolts 2 turns at a time. Remove rocker arm shaft assembly.
CAUTION :If rocker arm shafts are not loosened gradually, shafts may become bent or damaged.
Mark push rod location for installation reference, and remove push rods.
Remove and discard cylinder head bolts.
Remove cylinder head(s) and gaskets.
Need a tool or a tester CHECK IT @
https://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
LEEBAX
1993 Ford Explorer 6 cyl Two Wheel Drive Manual
is waterpump bad if hose from radiator is cool and all components are hot, hoses appear to be ok. I think my fan clutch is welded on
TOOOMANYTOYS
  • 513 POSTS
Yes it could be the water pump. However the thermostat and a clogged radiator could cause that also. You need to get an infared thermometer and try and find out which component has the blockage.
STEVEHALLOCK
1993 Ford Explorer Four Wheel Drive Automatic
I just replace the thermostat and while I let the motor run the bottom hose got hot and the top one did not. Also the coolant started to flow out the reserve resovoir. What can cause this and how can I fix it?
