1998 Ford Explorer Engine Flush
TXSUZY
Engine Mechanical problem
1998 Ford Explorer 6 cyl Two Wheel Drive Automatic
Despite this vehicle being a 98 model, it is just now reaching 40k miles. It hasn't been driven much overall, but hasn't been operated in about 5 years, save a trip around the block ever week or so. We have recently had it inspected, registered, battery replaced and went to have the oil changed and there was a problem. The plug was removed, but oil wouldn't drain, despite the dipstick showing it is full of oil. We were told to take it to a mechanic and have the engine flushed. I seriously doubt that the oil has EVER been changed, but cannot be certain.
Couple questions:
Whats the average price of this service?
Will it actually work to remove the sludge that is blocking?
Couple notes:
The engine sounds fine... no obvious knocking
Seems to run well
Oct 20, 2008 at 5:42 PM
MMPRINCE4000
  • 8,548 POSTS
Yes it will help, considering you would otherwise have to pull the pan.
You add the flush to the crankcase and IDLE the engine for 5 minutes, then drain the oil and change oil and filter. Do not drive the vehicle with the flush in there or rev the engine.
DO NOT USE FLUSH ON A TURBO ENGINE.
Oct 20, 2008 at 11:47 PM
