1998 Ford Explorer diagnosis/HELP?
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREXXX
I believe the front seal went out, after driving and all the fluid came out at once, I had nothing. Thought it was the tranny pan gasket, however replaced it and filter. While adding fluid on my second gallon, fluid everywhere. Was wondering what else it could be? and what else should be replaced ?,while tranny is out . Or if its even worth it, with so many miles and all the same problems as other 1998 ford explorer owners, like the timing chain noises,rough idle,drivers door not locking and I never went into ford to have the recalls done.
Jan 8, 2010 at 10:06 AM
  • 110,248 POSTS
IS the fluid coming out between the engine and transmission?
Jan 9, 2010 at 5:30 PM
GREXXX
yes it was coming between the motor and tranny
Jan 22, 2010 at 7:44 AM
